Knowledge Base Article
Internal Error: io_obuf_iterm->is_inverted() == comp_obuf_iterm->is_inverted()
Description
The above internal error may appear when you design a custom memory interface with the ALTDQ_DQS MegaCore®. The internal error is caused by inconsistent output enabling assignments on the DQS and DQSn signals.
Resolution
Make sure you have the same assignments on both DQS and DQSn signals.
Updated 3 months ago
Version 2.0
