Knowledge Base Article
Interlaken MegaCore Function 10.3125-Gbps Variation With Transceivers Runs at Incorrect Lane Rate
Description
The 10.3125-Gbps Interlaken MegaCore function variations with transceivers require a different ref_clk frequency than they were originally designed for. If you use the Interlaken 12-lane, 10-Gbps variation as generated, the lane rate is 10.2 Gbps rather than 10.3125 Gbps, in simulation and when programmed on the device.
Therefore, in addition to running the ref_clk input clock at 322.265625 MHz as specified in the Interlaken MegaCore Function User Guide, you must also make some manual modifications to several of the RTL files.
Resolution
After you generate your Interlaken variation and before you simulate your design, follow these steps to modify your RTL files to fix the underlying problem:
  1. Edit the file alt_ntrlkn_gxb_10g.v with the correct values to match the 322.265625-MHz ref_clk frequency by following these steps:
  2. To set the correct effective data rate, replace every instance of 10200 with 10312.5.
    To set the correct input period, replace every instance of 3137 with 3103.
    To set the correct input clock frequency, replace every instance of 318.75 with 322.265625.
  3. Edit the submodules/<variation>.sdc file with the correct clock frequencies by following these steps:
  4. Set tx_mac_c_clk frequency to 257.81 MHz.
    Set the rx_mac_c_clk frequency to 257.81 MHz.
If you are using the Qsys design example provided with the Interlaken IP installation, follow these additional steps:
  1. In the alt_interlaken_12lane_10g.sdc file in the project directory, set the following clock frequencies:
  2. Set the Sample Channel Client clock frequencies to 257.81 MHz
    Set the tx_mac_c_clk frequency to 257.81 MHz
    Set the ref_clk frequency to 322.265625 MHz
  3. In the testbench/alt_interlaken_12lane_10g_tb.sv file, update the ref_clk frequency by replacing #1568 with #1551.5.
This issue is fixed in version 11.0 of the Interlaken MegaCore function.
Updated 1 month ago
Version 2.0
