Knowledge Base Article
InstallShield error code -6001 when installing the MegaCore IP Library CD
Description
You may get the following error when you install the MegaCore® IP Library CD included with the Quartus® II software version 6.0.
Setup has experienced an error.
Please do the following:
- Close any running programs
- Empty your temporary folder
- Check your Internet connection (Internet-based Setups)
Then try to run the Setup again.
error code -6001
To work around this error, delete the C:\Program Files\Common Files\InstallShield\Professional\RunTime\0701 folder on your computer and reinstall the MegaCore IP Library CD.
If deleting the folder does not solve the problem, rename the C:\Program Files\Common Files\InstallShield folder to C:\Program Files\Common Files\InstallShield-old and reinstall the MegaCore IP Library CD.
This problem has been fixed beginnning with the Quartus II software version 6.1 MegaCore IP Library installation.
Updated 22 days ago
Version 2.0
