Knowledge Base Article
Incorrect Transceiver Reference Clocks in CPRI IP Core RE Variations
Description
In CPRI RE slaves, the transceiver PLL reference clock is not connected correctly.
This issue prevents the RE slave from completing link negotiation successfully in Arria V and Stratix V devices.
Resolution
To fix this problem in your CPRI RE slave instance that targets an Arria V or Stratix V device, you must edit the <project name>_002.v file after you generate your CPRI instance. In a text editor, perform the following substitutions:
- In the connection to the Rx transceiver (
inst_rx_xcvr), replacepll_ref_clk (inst_cpri_phy_pll_inclk_clk)with the new textpll_ref_clk (inst_cpri_phy_pll_ref_clk_clk). - In the connection to the Tx transceiver (
inst_tx_xcvr) replacepll_ref_clk (inst_cpri_phy_pll_ref_clk_clk)with the new textpll_ref_clk (inst_cpri_phy_pll_inclk_clk).
This issue is fixed in version 12.1 of the CPRI MegaCore function.
Updated 1 month ago
