Knowledge Base Article
Incorrect Error Message in MAX 10 EMIF
Description
This problem affects external memory interface products on MAX 10 devices.
During the fitter phase of compilation, the following incorrect error message may appear:
altmemphy pin placement was unsuccessful
The correct error message is as follows:
UniPHY pin placement was unsuccessful
Resolution
The workaround for this issue is to ignore the error in the error message.
This issue will be fixed in a future version.
Updated 2 months ago
Version 2.0
