Knowledge Base Article
Incorrect DisplayPort Maud Value When Transmit Audio Uses Quad Symbol Output Mode
Description
When you use the DisplayPort TX core configured in quad symbol output mode (4 symbols per clock) for audio operation, the calculated and transmitted 24-bit Maud value is incorrect. It is always twice the expected value.
Resolution
There is no workaround for this issue.
This issue is fixed in version 15.0 of the DisplayPort IP core.
Updated 22 days ago
