Knowledge Base Article
Incorrect Description of edgecapture Bit Clearing
Description
In the PIO Core chapter of the Embedded
Peripherals IP User Guide, a footnote to Table 10-2 incorrectly
states “Writing any value to edgecapture clears all
bits to 0.” This statement is only true if the Enable bit-clearing
for edge capture register option is turned off.
Resolution
The footnote should read as follows:
If the option Enable bit-clearing for edge capture register is
turned off, writing any value to the edgecapture register
clears all bits in the register. Otherwise, writing a 1 to a particular
bit in the register clears only that bit.
Updated 3 months ago
