Knowledge Base Article
Incorrect description in the Platform Designer User Guide
Description
For Quartus® Prime Pro Edition User Guide Platform Designer (UG-683609-817606) Versions 24.1 (2024.04.01) and earlier, section 6.1.8.5 contains an incorrect description of the option for enabling and disabling slave port control. In the document,  “select True for Enable Slave Control Port option” should be “select True for Disable Slave Control Port option”.
Resolution
The correct discription should be “select True for Enable Slave Control Port option”.
This description will be revised in a future release of the Platform Designer User Guide.
Updated 1 month ago
Version 2.0
