Knowledge Base Article
Incorrect Clock Uncertainty in UniPHY External Memory Interfaces
Description
A clock uncertainty related to the read FIFO clocked by DQS can result in inaccurate setup and hold slack values.
Resolution
The workaround for this issue is to manually edit the PHY .sdc file
located in the <variation_name>/constraints/
directory, and add the following two lines to the Multicycle Constraints
section of the file:
set_max_delay -from *ddio_in_inst_regout* -0.05
set_min_delay -from *ddio_in_inst_regout* [expr -
0.05].Updated 2 months ago
