Knowledge Base Article
In the ALTFP_SINCOS core, the sine of 210 degrees gives the wrong value.
Description
You may see this problem when implementing a sine function using the ALTFP_SINCOS Megacore in Quartus® II software versions 11.0 and 11.0SP1.
Resolution
To workaround this, change the <altfp_sincos_variant_file_name>.vhd file, line 22850 as follows:
Change from:
wire_mantissanorm_add_datab <= ( "0000000000000000000000" & mantissanormnode_w(12));
Change to:
wire_mantissanorm_add_datab <= ( "0000000000000000000000" & mantissanormnode_w(11));
Updated 2 months ago
