Knowledge Base Article
In the 10GBASE-R PHY MegaWizard Plug-In Manager, compilation fails for Stratix IV GX if you select a Starting channel number other than the default value 0
Description
In the 10GBASE-R PHY MegaWizard Plug-In Manager, if you select a Starting channel number other than the default value 0, compilation fails with an error similar to the following:
Error: Cannot find Memory initialization File or Hexadecimal (Intel-Format) File <file name> for ROM instance <instance name>
Resolution
Since every instantiation of the 10GBASE-R PHY megafunction includes a reconfiguration block, 0 is the correct starting channel number. Do not change the value of Starting channel number.
Updated 3 months ago
Version 2.0
