Knowledge Base Article
If you turn on Enable systolic delay registers in the ALTMULT_ADD MegaWizard Plug-In Manager generation fails for Stratix V
Description
On the Systolic/Preload page of the ALTMULT_ADD MegaWizard
Plug-In Manager, if you turn on Enable systolic delay registers,
generation fails with messages similar to the following:
Error: Illegal parameter value: SYSTOLIC_DELAY1 and SYSTOLIC_DELAY3
are used without chainin port
Error: Assertion error: The current megafunction is
configured for use with the clear box feature and cannot be used
when the clear box feature is disabled.
Resolution
The systolic delay registers feature is not available in the current release of the Stratix V ALTMULT_ADD megafunction. Do not turn on Enable systolic delay registers.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
