Knowledge Base Article
If my Verilog HDL design file has multiple cases listed on a single line of a Case Statement, only the first case appears to be implemented in the synthesized design. Why?
Description
The MAX PLUS® II software does not support multiple cases written on one line of a Case Statement in Verilog HDL designs.For example, the following code will only implement the first case, ignoring the second:
case(a) 2'b00, 2'b11: b <= 1; default: b <= 0; endcase
To avoid this problem, you should assign each case on a separate line:
case(a) 2'b00: b <= 1; 2'b11: b <= 1; default: b <= 0; endcase
This problem was fixed in the MAX PLUS II software versions 9.2 and above.
Updated 2 months ago
