Knowledge Base Article
HSSI power pin placement error for Arria 10 devices
Description
Different Arria 10 devices do not have the same high-speed serial interface (HSSI) power pin assignments. The 10AX115/090 device has right-side HSSI pins, but but the 10AX066/057 device does not. During compilation, the Quartus II Fitter should power down (GND) the unused HSSI power pins, but the pins are not powered down. When you migrate from a 10AX066/057 device to a 10AX115/090 device, the resulting merged project erroneously has right-side HSSI power pins (VCCR_GXBR, RREF and VCCH_GXBR).
Resolution
This issue is fixed in the Quartus II software version 15.0. There is no workaround for previous software releases.
Updated 2 months ago
Version 2.0
