Knowledge Base Article
HPD Issues with Arria V and Stratix V HDMI 2.0 Designs
Description
When you use a Hot-Plug Detect (HPD) line to connect the Bitec HDMI 2.0 HSMC daughter card RX port with a HDMI sink, the image may not display. This issue affects the HDMI design files provided with the ACDS version 15.0 targeting Arria V and Stratix V devices: av_sk_hdmi2 and sv_hdmi2.
This issue is not recoverable by resetting the connection or using another HPD line.
Resolution
There is no workaround for this issue.
This issue is fixed in version 15.0 Update 1 of the HDMI IP core.
Updated 2 months ago
Version 2.0
