Knowledge Base Article
How to program EPCQ-A devices used in an MAX®10 design?
Description
Due to the limitation that MAX® 10 devices do not come with any ASMI block, the Customizable Flash Programmer is suggested to be used for programming the EPCQ-A devices used
in your MAX® 10 design.
Resolution
Step 1:
Download the MAX® 10Customizable Flash Programmer design and change pin assignments for flash signals according to your kit. The Programmer Image provided is developed using the
Intel ® Quartus ® Prime Standard Edition Software version 18.0. You must compile the Programmer Image using the Intel Quartus Prime version 18.0 or later.
Step 2:
Download System Console TCL scripts (customizable_programmer.tcl and epcqa.tcl) used for EPCQ-A devices.
Step 3:
Generate the rpd. file needed for Customizable Flash Programmer.
Please refer to Customizable Flash Programmer User Guide Chapter 3.1.3.2. Generating .rpd File for Other FPGA Devices
Fill the quartus.ini with “PGM_ALLOW_QSPI128=ON” to enable 3-byte addressing, regardless of the flash density.
Select configuration device: QSPI128
Select mode: Active Serial x4
Step 4:
Download the modified “cust_prog_max10” design into your kit.
Step 5:
Run customizable_programmer.tcl and program command in the system console to program the RPD file into EPCQ-A.
% source customizable_programmer.tcl
% read_memory_id
% programming_flow test.rpd
Updated 3 months ago
Version 2.0
