Knowledge Base Article
How to mitigate the security vulnerability in the Nios® II Command Shell utility?
Description
Due to a problem in the Quartus® Prime Standard and Lite Edition Software version 19.1 through 24.1, the Nios® II Command Shell utility included in the Quartus® Prime Software for Windows* is vulnerable to a Current Working Directory (CWD) planting attack. The Linux* versions are not affected.
Resolution
To work around this problem, replace the “Nios II Command Shell.bat” Windows Batch File located in the <drive>:\<edition>\<version number>\nios2eds\, with the attached file below.
This problem is fixed beginning with the Quartus® Prime Standard and Lite Edition Software version 25.1.
Updated 2 months ago
Version 4.0No CommentsBe the first to comment
