Knowledge Base Article
How to generate a customized IP CORE in Quartus II software?
Description
You can use Quartus® II software to generate a customized IPCORE by following steps:
1.Create a new project, add the customer verilog/VHDL code file, then set this file as Top-Level Entity. And then run Analysis & Elaboration.
2.Select Quartus II software menu(Project -> Export Design Partation...) and generate the xxx.qxp file.
3.Use the generated xxx.qxp file as IPCORE.
Updated 2 months ago
Version 2.0
