Knowledge Base Article
How to enable the UART1 in ATF (Arm Trusted Firmware) when you configure the U-Boot to use UART1?
Description
Due to a problem in the Arm Trusted Firmware (ATF) version 2.4.0 and earlier, when uart1 is configured for U-boot, the HPS will hang.
Resolution
To work around this problem in the ATF version 2.4.0 and eariler, you could make a modification to use the real register address for UART1 in arm-trusted-frimware/plat/intel/soc/common/include/platform_def.h.
Here is an example for Agilex™ SoC devices (macro PLAT_UART0_BASE used across the ATF code, a simple modification is suggested here):
Change
#define PLAT_UART0_BASE (0xFFC02000)
to
#define PLAT_UART0_BASE (0xFFC02100)
Updated 1 month ago
Version 2.0
