Knowledge Base Article
How to determinate which type of nodes are affected by the Quartus Setting File (.qsf) assignment POWER_TOGGLE_RATE_PERCENTAGE?
Description
Because not every node on the design affects the power estimate, you must generate a Signal Activity File (.saf) to determine the output ports that are affected by the assignment POWER_TOGGLE_RATE_PERCENTAGE.
Resolution
This information is scheduled to be added in a future release of the Intel® Quartus® Prime Pro Edition User Guide: Power Analysis and Optimization.
Updated 2 months ago
