Knowledge Base Article
How to connect clock to pipe_pclk when using Intel® Arria® 10 FPGA Transceiver Native PHY in PIPE mode?
Description
tx_clkout is preferable for pipe_pclk. Its frequency will change automatically according to Gen1/Gen2/Gen3 speed and data width configuration.
Resolution
Depending on the link width configuration, always use the middle tx_clkout to minimize the clock skew between channels. For instances:
  •  x1 and x2 --> use tx_clkout[0]
  •  x4 --> use tx_clkout[1] or tx_clkout[2]
  •  x8 --> use tx_clkout [3] or tx_clkout[4]
The hclk_out port of Native PHY can be left floating. It is basically a feed through version of the hclk_in supplied by the Tx phase-locked loop (PLL). Typically, this clock is not used because its frequency is fixed. It's only used if the 3rd party intellectual property (IP) requires a fixed frequency clock.
Updated 3 months ago
Version 2.0
