Knowledge Base Article
How should the data in the RPD file be set up for programming quad-serial (EPCQ) devices that are 256Mb or larger?
Description
When programming EPCQ devices that are 256Mb or larger with an RPD file in Active Serial (AS) mode, you need to set it in 4-byte addressing mode before programing, otherwise it will cause a configuration failure.
Resolution
To set the EPCQ device in 4-byte addressing mode, refer to 4BYTEADDREN operations in Quad-Serial Configuration (EPCQ) Devices Datasheet (PDF).
Updated 2 months ago
