Knowledge Base Article
How should the configuration data be transmitted when using Fast Passive parallel (FPP) x8, x16 or x32 configuration modes, when using Raw Binary Files (.rbf)?
Description
The configuration data in the raw binary programming file is little endian.
If the .rbf contains the byte sequence 02 1B EE 01 (as an example) then see below on how this data should be transmitted in FPP x8, x16 or x32 modes respectively:
a) In FPPx8 mode, the LSb (least significant bit) of a byte is BIT0, MSb (most significant bit) is BIT7.
BYTE0 = 02
BYTE1 = 1B
BYTE2 = EE
BYTE3 = 01
D[7..0]
D[7..0]
D[7..0]
D[7..0]
0000 0010
0001 1011
1110 1110
0000 0001
b) In FPPx16 mode, the first byte in the file is the LSB (least significant byte) of the configuration word, and the second byte is the MSB (most significant byte).
WORD0 = 1B02
WORD1 = 01EE
LSB: BYTE0 = 02
MSB: BYTE1 = 1B
LSB: BYTE2 = EE
MSB: BYTE3 = 01
D[7..0]
D[15..8]
D[7..0]
D[15..8]
0000 0010
0001 1011
1110 1110
0000 0001
c) In FPPx32 mode, the first byte in the file is the LSB (least significant byte) of the configuration double word, and the fourth byte is the MSB (most significant byte).
Double Word = 01EE1B02
LSB: BYTE0 = 02
BYTE1 = 1B
BYTE2 = EE
MSB: BYTE3 = 01
D[7..0]
D[15..8]
D[23..16]
D[31..24]
0000 0010
0001 1011
1110 1110
0000 0001
Resolution
Ensure you do not swap the upper bits or bytes and the lower bits or bytes when performing FPP configuration. Incorrectly sending the configuration data during the configuration process may cause unexpected behavior on the CONF_DONE signal.
Updated 2 months ago
Version 2.0
