Knowledge Base Article
How should the CKE signal be terminated for DDR3 and DDR4 interfaces?
Description
The CKE signal is pulled down to GND on the DDR3 HiLo daughter card and terminated with a Thevenin parallel termination on the DDR4 HiLo daughter card.
Resolution
All address and command signals, including the CKE signal, should use a fly-by termination for Arria®10 and Stratix®10 DDR3 and DDR4 interfaces.
These signals should be terminated with a resistor to VTT at the end of the fly-by topology. This termination is required only for discrete memory device implementations and is not required for DIMMs.
Updated 2 months ago
Version 2.0
