Knowledge Base Article
How should I connect the Reset Input Ports of Altera Dual Clock FIFOs?
Description
Altera provides highly configurable FIFO implementations.  In FIFO implementations that have a separate clock for the data input (Slave, Sink, Receiver) and the data output (Master, Source, Sender) interfaces, the corresponding resets for each clock domain must be asserted at the same time.  This ensures that the internal input data pointers and output data pointers are aligned after reset deassertion.
The Altera components that implement a dual clock FIFO are:
  • Avalon-MM Clock Crossing bridge
  • Avalon-ST Dual Clock FIFO
  • Avalon FIFO Memory
Resolution
In order to reset both data input and data output sides of dual clock FIFOs that have two reset inputs, each reset input port should be connected to the same reset source. The following list shows which reset input ports for which components should be connected to the same reset source:
  • For the Avalon-MM Clock Crossing bridge, connect these inputs to the same reset source:
    • m0_reset
    • s0_reset
  • For the Avalon-ST Dual Clock FIFO, connect these inputs to the same reset source:
    • in_clk_reset
    • out_clk_reset
  • For the Avalon FIFO Memory, connect these inputs to the same reset source:
    • reset_in
    • reset_out
This information is scheduled to be included in a future release of the Quartus II handbook.
Updated 2 months ago
Version 2.0
