Knowledge Base Article
How should I connect the refclk and adjpllin ports in the PLL Intel® FPGA IP when using the dedicated cascade path?
Description
There are two reference clock inputs (refclk and adjpllin) when the PLL Intel® FPGA IP is configured with the Cascade Downstream PLL option enabled.
Resolution
You need to connect the upstream "Cascade out" signal to the adjpllin input port and you can leave the refclk input unconnected.
Updated 3 months ago
Version 2.0
