Knowledge Base Article
How should I configure the Auto_Negotiation feature of the Triple-Speed Ethernet IP Core when using SGMII mode?
Description
You should set 0 to both AUTO_NEGOTIATION_ENABLE and USE_SGMII_AN registers of the Triple-Speed Ethernet MegaCore® Function to turn off the SGMII Auto-Negotiation feature.
Resolution
To turn on the SGMII Auto-Negotiation feature, you should set 1 to both AUTO_NEGOTIATION_ENABLE and USE_SGMII_AN registers. For more details on SGMII configuration, refer to the Triple-Speed Ethernet System with the SGMII section of the Triple-Speed Ethernet MegaCore Function User Guide (PDF).
Updated 2 months ago
