Knowledge Base Article
How is the ZL30733 device controlled on the Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit?
Description
When using the Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit, the description of how the ZL30733 device is controlled is wrong in section  4.3. Control On-Board Clock through Clock Controller GUI of the Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit User Guide.
The wrong description is "The clock controller communicates with the system MAX® 10 device through a 10-pin JTAG header J11 or USB port J10. Then, system MAX® 10 controls these programmable clock parts through a 2-wire I2C bus."
Resolution
The description will be corrected and updated as below:
The Clock Controller communicates with the system MAX® 10/Agilex™ 7 FPGA device through a 10-pin JTAG header J11 or USB port J10. The system MAX® 10 FPGA controls Si5394/Si5391-A/Si5391-B/Si5332, and the Agilex™ 7 FPGA device controls ZL30733 through the I2C bus.
Updated 3 months ago
Version 2.0
