Knowledge Base Article
How do you show all panes when running Report Timing task in the TimeQuest timing analyzer?
Description
In the Quartus® II software versions 10.0 and later, when running the Report Timing task, the TimeQuest timing analyzer may display the following windows panes minimized :
- Path Summary
- Statistics
- Data Path
- Waveform
- Extra Fitter Information
The only window pane that appears is the Summary of Paths.
To work around this problem, resize the panes by positioning the cursor near the bottom of the pane between the Summary of Paths table and the Console window, and click and drag the window divider upwards.
Updated 2 months ago
