Knowledge Base Article
How do you define the ramp rate [Ramp] in the IBIS File?
Description
While the rise and fall time is defined as the time it takes from the output to go from 20% to 80% of its final value, the ramp rate is defined as:
dV 20% to 80% voltage swing
dt Time it takes to swing the above voltage
The ramp rate must be specified as an explicit fraction and must not be reduced. The [Ramp] values can use "NA" for the min and max values only.
Updated 2 months ago
