Knowledge Base Article
How do I verify the correct frequency of divfwdclk when an incorrect frequency of divfwdclk is shown in the Quartus Prime TimeQuest Timing Report?
Description
The frequency of divfwdclk  shown in Quartus® Prime TimeQuest timing report for certain combinations of data rate and SERDES factor in Stratix® V devices may be incorrect. For example:
Enable Dynamic Phase Alignment
Deserialization factor = 10
Input date rate = 150Mpbs
Input clock frequency = 150Mhz
DPA mode : use divfwdclk
The divfwdclk should be 150MHz/10 = 15MHz, but TimeQuest reports a divfwdclk of 30MHz.
Resolution
To work around this issue, use the create generated clock command in a user SDC file or in the TimeQuest Timing Analyzer to divide the divfwdclk to the correct frequency. For example:
create_generated_clock -name divfwdclk -source [get_pins {rx_cmp_inst|ALTLVDS_RX_component|auto_generated|rx_0|dpaclkin[0]}] -divide_by 2 [get_pins {rx_cmp_inst|ALTLVDS_RX_component|auto_generated|rx_0|divfwdclk}]
Updated 1 month ago
Version 2.0
