Knowledge Base Article
How do I simulate Stratix V designs in VHDL using the ModelSim-Altera Starter Edition software?
Description
Due to a problem in the ModelSim-Altera Starter Edition software versions 6.6c and 6.6d, designs in VHDL targeting Stratix® V devices cannot be simulated. This problem does not affect the ModelSim-Altera Edition software. These versions of the ModelSim-Altera Starter Edition are provided with the Altera Complete Design Suite versions 10.1 and 11.0.
Due to this problem, you may see errors such as the following:
# ALTERA version supports only a single HDL
# ** Fatal: (vsim-3612) Instantiation of 'stratixv_ds_coef_sel' failed. Unable to check out Verilog simulation license.Resolution
To work around this problem, use one of the following options:
- Simulate your design targeting Stratix V devices using Verilog HDL.
- Simulate your design targeting Stratix V devices using the ModelSim-Altera Edition software.
This problem is fixed beginning with the ModelSim-Altera Starter Edition software version 10.0c provided with the Altera Complete Design Suite version 11.1.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
