Knowledge Base Article
How do I preload the UniPHY-based memory model during RTL simulation?
Description
When you generate the example design for the UniPHY-based external memory controllers, a generic memory model is created. This memory model has a memory array that can be preloaded with known values using a memory initialization file. To preload the memory array, perform the following steps:
  • Open the alt_mem_if_common_ddr_mem_model_ddr3_mem_if_dm_pins_en_mem_if_dqsen.sv file.
  • Create a memory initialization file with the following address & data format. The address & data are hexadecimal values, and the address does not need to be contiguous.
@0000 DEADBEEF
@0001 FEEDFACE
@0104 01234567
  • Set the MEM_INIT_EN parameter to 1 to enable memory preloading.
  • Set the MEM_INIT_FILE parameter to the path of the memory initialization file.
Updated 3 months ago
Version 2.0
