Knowledge Base Article
How do I pass parameters through multiple levels of hierarchy of schematic files in the Quartus II Schematic Editor?
Description
To pass parameters through multiple levels of schematic files in the Quartus® II software, use the param primitive symbol located under <Quartus II installation directory>/quartus/libraries/primitives/other/param.
- Insert the param symbol into your block design file
- In the param Properties dialog box, set a name and value for the parameter
- Assign the lower level block parameter to the name of the param symbol
Updated 2 months ago
