Knowledge Base Article
How do I modify the UniPHY example driver to run continuously?
Description
By default, the driver only runs once when you use the UniPHY example project.
To make the driver run continuously, modify the driver file at the location "<variation_name>_example_design\example_project\<variation_name>_example\submodules" named as either
driver_avl_use_be_avl_use_burstbegin.sv or driver_avl_use_burstbegin.sv
Change the following line
defparam driver_fsm_inst.NUM_DRIVER_LOOP                = TG_NUM_DRIVER_LOOP;
to
defparam driver_fsm_inst.NUM_DRIVER_LOOP                = 0;
This change will enable the UniPHY example driver to run continuously.
Resolution
Updated 3 months ago
Version 2.0
