Knowledge Base Article
How do I map the transceiver toolkit pre-emphasis 2nd post-tap settings to the Quartus II transceiver QSF assignments in Stratix V GX and Arria V GZ devices?
Description
The pre-emphasis 2nd post-tap is selectable between -15 to 15 on Stratix® V GX and Arria® GZ devices. You can set the Quartus® II pre-emphasis 2nd post-tap QSF assignments by using either the XCVR_TX_PRE_EMP_2ND_POST_TAP and XCVR_TX_PRE_EMP_INV_2ND_TAP QSF assignments, or you can set the XCVR_TX_PRE_EMP_2ND_POST_TAP_USER QSF assignment.
The mapping of these settings to the Stratix V GX Transceiver Toolkit is defined below.
Toolkit Setting XCVR_TX_PRE_EMP_2ND_POST_TAP Setting XCVR_TX_PRE_EMP_INV_2ND_TAP Setting XCVR_TX_PRE_EMP_2ND_POST_TAP_USER Setting
1515FALSE1
1414FALSE2
1313FALSE3
1212FALSE4
1111FALSE5
1010FALSE6
99FALSE7
88FALSE8
77FALSE9
66FALSE10
55FALSE11
44FALSE12
33FALSE13
22FALSE14
11FALSE15
00TRUE/FALSE16
-11TRUE17
-22TRUE18
-33TRUE19
-44TRUE20
-55TRUE21
-66TRUE22
-77TRUE23
-88TRUE24
-99TRUE25
-1010TRUE26
-1111TRUE27
-1212TRUE28
-1313TRUE29
-1414TRUE30
-1515TRUE31
Related Articles
Updated 3 months ago
Version 2.0
