Knowledge Base Article
How do I instantiate 74-series macrofunctions in VHDL? (MAX PLUS® II)
Description
Component declarations for the 74-series macrofunctions are provided in the <max plus II directory>\vhdlxx\altera directory, where xx is either "87" or "93".Since VHDL does not allow function names or port names beginning
with a number, they are preceded by a_ in the component declaration.
Refer to the following example of the nand function (7400):
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY altera; USE altera.maxplus2.ALL; ENTITY my_nand IS PORT ( my_in0 : IN STD_LOGIC; my_in1 : IN STD_LOGIC; my_out : OUT STD_LOGIC ); END my_nand; ARCHITECTURE behavior OF my_nand IS BEGIN u1: a_7400 PORT MAP ( a_2 => my_in0, a_3 => my_in1, a_1 => my_out); END behavior;
Updated 3 months ago
