Knowledge Base Article
How do I install a "virtual" adapter to install TCP/IP protocol support on my stand-alone computer?
Description
You need to install the TCP/IP protocol for the Quartus™ software to compile. If your computer is not on a network, or does not have a network card, there is a virtual adapter that can be installed and allows you to install the TCP/IP protocol on your stand-alone computer.To install the "virtual adapter", do the following:
Windows NT 4.0:
- Go to the Control Panel.
- Select Network.
- Click on the Adapters tab.
- Choose the Add button and select MS Loopback Adapter. This virtual Microsoft adapter allows you to install TCP/IP on a PC without a network card or modem. You need the Windows NT 4.0 CD ROM in order to install this driver.
- Use the default Frame Type value (802.3) and click OK.
- Click on the Protocols tab.
- Choose the Add button and select TCP/IP Protocol.
- Click Close to exit the window.
Windows 98:
- Select Network.
- Choose the Configurations tab, and click on the Add button.
- In the Select Network Component Type window, choose Adapter and click on the Add button.
- In the Select Network Adapters window, choose:
Manufacturer: Microsoft
Network Adapters: MS Virtual Private Networking Adapter, and click on OK. - Now that you are back in the Configurations tab, click on the Add button again.
- In the Select Network Component Type window, choose Protocol, and Click on the Add button.
- In the Select Network Protocol window, choose:
Network Protocols: TCP/IP and click on OK. - Click OK to exit the window.
Updated 2 months ago
