Knowledge Base Article
How do I infer the pre-adder in the Variable Precision DSP Block of a Cyclone V device?
Description
To infer the pre-adder in the Variable Precision DSP Block of the Arria® V, Cyclone® V, and Stratix® V device families be sure to resize your data inputs to the pre-adder by an additional bit to account for the carry within the pre-adder function.
Resolution
To see an example of what this might look like use the Quartus II software templates available from the Edit > Insert Template... > VHDL > Full Designs > Arithmetic > DSP Features (Stratix-V, Arria-V and Cyclone-V). Select one of the multiplier templates with operands from the pre-adder, for example Multiplier with One Operand from Pre-Adder template.
These same templates are also available via the Verilog templates.
Updated 2 months ago
