Knowledge Base Article
How do I get package RLC parasitic value per pin for Intel® Stratix® 10 devices?
Description
The RLC parasitic value for each pin of Intel® Stratix® 10 devices is not included in the stratix10 rlc.xls file which can be downloaded from  IBIS Models for Intel® Devices
You need to generate the IBIS model first based on your target device and enable RLC option when generating the model.
Resolution
You can generate an IBIS model file with Intel Quartus Prime® Edition software based on your target device and  pin assignment and get the RLC value by following these steps.
Go to Settings--> EDA Tool Settings--> Board level signal integrity analysis--> format: IBIS and enable model selector and extend model selector.
Then re-compile the design after applying these settings.
The RLC value for each pin used in your project will be included in the generated *.ibs file as shown in the example below. The RLC values are listed in the right column.
[Pin] signal_name                                     model_name                             R_pin L_pin C_pin
AA1 tx_datak(2)~pad                               18_rtin_lv                                  1075.3m 6.327nH 2.200pF
AA2 tx_parallel_data(2)~pad                 18_rtin_lv                                   976.1m 5.828nH 2.147pF
AA4 tx_parallel_data(15)~pad               18_rtin_lv                                  831.8m 4.855nH 1.948pF
AA5 VCCIO3A POWER
AA8 tx_parallel_data(20)~pad               18_rtin_lv                                  969.1m 5.378nH 2.470pF
AA9 tx_datak(1)~pad                               18_rtin_lv                                  993.4m 5.810nH 2.499pF
AB1 tx_parallel_data(24)~pad               18_rtin_lv                                  1074.7m 6.252nH 2.237pF
Updated 3 months ago
Version 2.0
