Knowledge Base Article
How do I generate a Serial Vector File (SVF) in Quartus II software?
Description
To generate an SVF file in Quartus® II software, follow the steps below:
  1. Open the Quartus II programmer and add a .sof / .pof file into the programmer window.
  2. Select the File Menu then select Create/Update within this menu choose Create JAM, SVF, or ISC File.
  3. Input a file name for your SVF file output.
  4. In the File Format drop-down select Serial Vector File (SVF) as your output file type.
  5. Press ok to generate your SVF file.
Related Articles
Updated 3 months ago
Version 2.0
