Knowledge Base Article
How do I find my server Host ID on a UNIX platform needed to request an Altera license file?
Description
To find your host ID, follow the steps below for your platform:Sun SPARCstation
Your host ID is an 8-digit hexadecimal number.
Type the following command at a UNIX prompt for SunOS 4.1.3 and lower:
/usr/bin/hostid ![]()
Type the following command at a UNIX prompt for Solaris 2.5 and later:
/usr/ucb/hostid ![]()
HP 9000 Series 700/800
Type the following command at a UNIX prompt:
/usr/bin/uname -i ![]()
Transpose the resulting value into hexadecimal format, and use that value as the host ID.
IBM RS/6000
/usr/bin/uname -m ![]()
You will receive a 12-digit number. Remove the first 2 digits and the last 2 digits; the host id is the middle 8 digits. For example, the number 000276513100 converts to the host id 02765131.
| Refer to the documentation for you operating system, or contact your system administrator for more details about these commands. |
Updated 10 months ago
