Knowledge Base Article
How do I execute the CFI flash programming without the verify operation through the Parallel Flash Loader (PFL) with a .jam or .jbc file?
Description
When you execute the PROGRAM action in the .jam or .jbc file, the PFL will typically perform erasing, programming and verifying process. Hence it will take a longer time to complete the CFI flash programming. You can skip the verify operation when programming the CFI flash device, by disabling the DO_VERIFY procedure, when executing the .jam or .jbc file.
If using the quartus_jli executable, the command would be :
quartus_jli –c<cable index> –aPROGRAM –dDO_VERIFY <filename>.jam/.jbc
If using the JAM STAPL player, the command would be:
jam –aPROGRAM –dDO_VERIFY=1 <filename>.jam
The Jam STAPL Byte-Code (jbc) Player uses the same command as above to run a .jbc file, except for the executable name.
Related Articles
Updated 2 months ago
