Knowledge Base Article
How do I estimate transceiver E-Tile Channel PLL power for Intel® Stratix® 10 TX, MX, and DX devices in the Intel® Quartus® Prime Power Thermal Calculator (PTC) tool?
Description
You can estimate transceiver E-Tile Channel PLL power for Intel® Stratix® 10 TX, MX, and DX devices in the Intel® Quartus® Prime PTC tool by adding a “Transmitter Only” line in the “Transceiver" page of the PTC.
Resolution
The following three examples show how to configure the PTC for your desired E-Tile channel PLL requirements.
E-Tile Channel PLL configured for:  Reference clock = 200MHz, pll_clkout1 = 800MHz, pll_clkout2 = 400MHz,
Operation Mode,    Data Rate (Mbps),   Digital/Analog Width,   Power Mode,      FEC,         EHIP,       Modulation,   Digital Freq,   #Refclks,   Refclk Freq,   VOD
Transmitter Only,   12800,                       16                                     Normal Power,   Bypass,   Bypass,   NRZ,                0,                      1,                200,                0
E-Tile Channel PLL configured for:  Reference clock = 125MHz, pll_clkout1 = 500MHz, pll_clkout2 = 250MHz,
Transmitter Only,   8000,                         16,                                     Normal Power,   Bypass,   Bypass,  NRZ,                 0,                      1,               125,                 0
E-Tile Channel PLL configured for:  Reference clock = 307.2MHz, pll_clkout1 = 491.52MHz, pll_clkout2 = 245.76MHz,
Transmitter Only,   19660.8,                   40,                                     Normal Power,   Bypass,   Bypass,   NRZ,                0,                      1,                307.2,             0
Alternatively, you can instantiate an E-Tile Transceiver Native PHY IP in PLL mode in your Intel® Quartus® Prime project, compile the project, and view the configuration in the PTC.
This information will be added to a future revision of the Intel® FPGA Power and Thermal Calculator User Guide.
Updated 3 months ago
Version 2.0
