Knowledge Base Article
How do I ensure consistent behavior between Avalon-MM and Avalon-ST PCIE HIP in the Stratix V device family?
Description
For the Stratix® V device family, to ensure consistent behavior between the Avalon®-MM and Avalon-ST PCI Express® Hard IP, 3 parameters need to be changed from the Avalon-MM wrapper to match the default values in the Avalon-ST wrapper.
Resolution
In the file altpcie_sv_hip_avmm_hwtcl.v, look for the following parameter definitions near the top of the file (around line 37 and 148) and make the changes identified:
   parameter deskew_comma_hwtcl         =  "skp_eieos_deskw",
   parameter rx_cdc_almost_full_hwtcl   =  6,
   parameter tx_cdc_almost_full_hwtcl   =  6,
Change to:
   parameter deskew_comma_hwtcl         =  "com_deskw",
   parameter rx_cdc_almost_full_hwtcl   =  12,
   parameter tx_cdc_almost_full_hwtcl   =  11,
Updated 3 months ago
Version 2.0
