Knowledge Base Article
How do I enable the Avalon override in RTL simulation for PHY Lite for Parallel Interfaces Intel® Agilex™ 7 FPGA IP ?
Description
Due to a problem in Quartus® Prime Pro Edition Software version 22.4, the RTL simulation with Dynamic Reconfiguration will not perform writing to the Avalon® Memory Mapped interface because it is disabled by default.
Resolution
To work around this problem in Quartus® Prime Pro Edition Software version 22.4, write 32'b1 to the byte control register address to enable the Avalon* override. In the PHYlite example design with Dynamic Reconfiguration, this step is performed as the IOSSM_INIT_WRITE state in the test_logic_iossm module of the tester IP.
Additional Information
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 23.1.
Updated 1 year ago
