Knowledge Base Article
How do I enable compression when generating programming files using the Convert Programming Files utility?
Description
To enable compression when generating programming files using the Convert Programming Files utility in the Quartus® II software, follow the steps below :
(1) After adding .sof file to Input files to convert list, highlight the .sof file.
(2) Click Properties.
(3) Check Compression
(4) Click OK
Updated 2 months ago
