Knowledge Base Article
How do I enable autonomous Hard IP in my Arria V or Cyclone V design using Quartus II version 13.1 and earlier?
Description
To enable autonomous Hard IP(HIP) in your Arria® V or Cyclone® V design using Quartus® II software version 13.1 and earlier, follow the workaround/fix steps below:
Ensure that your device has a die revision capable of autonomous HIP.  For detail, refer to the Configuration via Protocol section of your target device Errata Sheet in the following link.
http://www.altera.com/literature/lit-es.jsp
Resolution
Create a quartus.ini file that include the below settings in the INI file. This quartus.ini file should be save in the quartus project directory. If you already have a quartus.ini file, add the below settings to it.
PGMIO_ENABLE_AUTONOMOUS_HIP_MODE=ON
PGMIO_DISABLE_AV_CV_AUTONOMOUS=OFF
Related Articles
Updated 1 month ago
Version 2.0
