Knowledge Base Article
How do I enable a breakpoint for only one Nios II processor in a system with multiple Nios II processors
Description
A breakpoint will be enabled for all Nios® II processors within a system by default, even if separate software projects are used for the different processors.
Resolution
To enable a breakpoint for just one Nios II processor, open the breakpoints window (Window > Show View > Breakpoints), right click on the breakpoint of interest and select Breakpoint Properties, then set Filtering to restrict the breakpoint to the processor of interest.
Updated 2 months ago
Version 2.0
