Knowledge Base Article
How do I disable or bypass the output register of DSP block on Cyclone V, Arria V and Stratix V devices by using ALTMULT_ADD Megafunction?
Description
In order to disable or bypass the output register of DSP block on Cyclone® V, Arria® V and Stratix® V devices, you have to uncheck both "Add extra register(s) at the output" and "Register Output of the multiplier" parameters in ALTMULT_ADD Megafunction.
Updated 1 month ago
